2008 Colorado Extended Cab Airbag Warning Light.
Truck Specs 2008 Colorado Extended Cab 4X4 Z71
Jumped in the truck last Monday, fired it up and the red warning light for the airbag system was lit up on the instrument panel.
Shut the truck off, waited 60 seconds, in case it was a “glitch in the airbag system”, fired the truck back up but airbag red warning light was still illuminated. Activated OnStar, OnStar ran diagnostics and confirmed airbag system inop with two faults ( Drivers Seat Belt pre-tensioner failed and Drivers Seat Belt pre-tensioner wiring open or shorted).
Review of the wiring schematics show the wiring for the drive Drivers Seat Belt pre-tensioner running from the Cab to the Ext-Cab door. As these wirers transition from the Cab through a boot to the Ext-Cab door, I pulled the boot back to expose the wires and SHAZAM! Broken pre-tensioner wire… As I looked closely to the wires in the boot, all the wires, (speaker, door switch etc.) were all fatigued from the day to day use of opening and closing the Ext-Cab door.
Called up my local Chevy dealer which is a sponsor of our Covette club and the Parts Guru pulls up the harness in the system P/N 15214393 and has it available.
Below are a few pics of the replacement and make damn sure you pull the fuse on the airbag system before doing this harness replacement, even with the key off, the airbag system does store voltage to deploy the airbags.
This task to just less than 3 hours to perform with multiple beverage breaks!
Gaining access to remove the harness, all this will be needed to be removed from the Cab to the Ext-Cab door
Replacement Harness
Disconnect harness from speaker, door switch seat belt reel then detach harness from Ext-Cab door.
Pop cab grommet and feed door harness into cab to disconnect the two wire harness connectors.
For installation, follow steps in reverse, start truck and red warning light with go through the normal test sequence then extinguish.
Hope that this info will be useful,
Cheer,
Vetteman
Replacement Harness
Cheer,
Vetteman
