I am a new owner of an 05' zq8 /I5/ Crew cab (had it about two weeks) it has 74k on it.
It was running great until three days ago. Check engine light came on!!
Had it diagnosed at AutoZone.....#0305 _Misfire in Cyl #5
Changed plugs, changed coil, changed both O2 sensors (not all at once..code kept appearing so i kept digging). The code still pops up about 20 minutes after I reset it. I know some have taken theirs to the dealer due to intake gasket, exhaust value issues. Doesn anyone have any concrete causes for this?
I will have to wait a few days because I want to make sure it isn't the gas either. I put 93 oct and some 104 fuel injector cleaner /octane booster in it before the engine light issue. (This was was about two days before the engine light issue which makes me feel it isn't the gas).
Also, is it true engine issues are covered until 100k? I saw a link on an older thread to a bulletin on CFforums but I'm not a member there.
It runs great but the idle does seem a bit twitchy at times. Acceleration is good as well.
ANY HELP is greatly appreciated.
Thank you so much
Jae
Thank you so much
Jae
