Dana 44 project
16K views 47 replies 10 participants last post by  cv6767
I have read a thread on pirate where someone did this with a h3. She made a new subframe to mount it. The more I looked at it the more i thought i could do it so i cut down my dana 44 today. I cut it down as much as i thought i could on the drivers side hoping it will fit. it seems close just waiting for the ford housing ends to come in to button it up.
Hoping to get this in and running 2500 axle shafts. I have h3 knuckles coming in the mail. I'm pretty sure they will bolt up and then can use the h3 unit bearing that's 33 spline like the 2500.
I do have a request of the 4wd guys. Can someone post pics up of the front diff and how it mounts? i know it bolts to the frame just want an idea of the mounts the factory used.
#3 ·
I remember her name was bebe I believe. They used a 2500 axle I believe and shafts. This should be interesting.
#8 · (Edited)
Dude! I think you cut the wrong side unless your changing transfer cases. Should have cut off the passenger side. Our differential is on the passenger side. You will need a Arb locker with 33 spline side gears. You have to fab up new upper and lower control arms. Those knuckles use a different upper ball joint. I was going to do this myself at one point but a SAS seems easier since you have to go all custom anyway.
This is going in a 2wd z71. So i don't have any existing 4wd stuff to go off of. The drivers side actually has more room and will fit the diff better and since I'm starting with a 2wd the drive shaft won't be a weak link.
i shouldn't have to have new spider gears. i am going to try to get axle shafts made that will fit the stock carrier and have the 2500 cv shaft bolt pattern.
And i noticed the ball joint being different. I plan on making some new uppers with a uniball to fix this and give me a little extra travel.
#10 ·
You should coil over that and run a divorced tcase.
#11 ·
In this event "why not just sas" is the perfect question. However, being that the tubes are already cut its irrelevant. Gonna need new ucas, hubs, custom cvs, tcase, both driveshafts, never mind all the fab work to make it all fit. Ill be $2k into both my axles locked, geared, and installed. Youll be near that with a semi custom stock ish ifs. Kudos on the ambition and skill needed to pull off this odd but cool project.
#12 · (Edited)
Actually I'm going to try to keep as much stock as I can.
And i knew the sas question would come up and the main thing is down time. i can swap most of the ifs parts in a weekend and still be able to drive the truck with just the diff hanging under it.
Price wise I'm gonna be about the same eventually I think. But that's because i'm starting with a 2wd. Either way the drive shafts, transfer case and fab work would have to be done.
Axle was free though. Probably be a couple hundred in it though with the stub shafts. The knuckles for the h3 cost me 100 bucks shipped and the only thing i really should need made will be the upper a arms and the stub shafts for the diff. I'm waiting to find some 2500 cv shafts cheap. But using those will keep most wear out parts stock so if anything breaks its not a week down time waiting on replacements.
Was considering coilovers but want to keep it relatively easy right now. will get some tubular a arms with a uniball made and will go ahead and make sure they have room for coilovers so I can fo it down the road from now. And I'm hoping to put the np241 from 1/2 ton in it. They are drivers drop and bolt up to the 4l60e.
#13 ·
I think it will be a tight fit but it will work in there. You can see in the last two pics how close it is to the oil pan. I will be grinding these couple ribs down to give me some clearance there. That should let me move it up an inch or so more. The yoke looks close to the a arm but there is plenty or room for it to spin. I will be solid mounting it so it shouldn't move around any down there.
#14 ·
OK, I was worried for a second. A leaf sprung SAS would be a pretty quick turn around time if everything was already collected. What are you going to do to disengage the front differential? H3 are awd Soviet doesn't matter. But you will lose some fuel economy and gain more we war and tear as your driveshaft will be moving all the time.
#16 ·
On our stock 4x4 front differential there is a collar that disengages the driver side CV axle from the pumpkin so the spider gears and spin. Our driveshaft does not spin unless that collar gets engaged(there is a electric actuator). Your driveshaft will always spin so there will be more drag. On a h3 they don't have that collar they are always engaged. Just something to keep in mind.
I think only about 1/2-1" lower than the front cross member viewed from the front. Will double check when I get home.
#18 ·
you could make a similar system since you are already making a custom intermediate shaft.
some newer dana 44's had a system built in. 90's dodge front axles also could source the shafts and have the outer portion adapted to what you need. no one likes those axle so you could probably pick one up cheap. when i wanted to do this swap i was going to do that or find a way to use lockout hubs like isuzu and toyota use to have on their ifs.
#21 ·
It's not going to work. Trust me already tried two different diffs. The thread you are referring to was by reaper an h3 owner who did something similar. What the thread did not show was that the passenger side shaft was custom and really really short to allow the pinion and housing to clear the oil pan. 2500 shafts are too long to do this and it is not a good idea to make the cv that short as it increases the angle seen by the cv and increases axle plunge.
#23 ·
you might be better off using a chevy 3/4 ton/1 ton ifs front diff. already driver side. it is setup for the cv's you will be using. that would kill the need for any custom shafts and you could disengage the drive shaft. that would be by far the cheapest and easiest to fab up.
just throwing out ideas. it's a high pinion also so if you drop the diff down the driveshaft will still tuck nicely.
#25 ·
What spline count are our hubs and what spline count is the 2500 cvs?
Imo a leaf sprung sas will be around $2000 and soa the rear and youll sit clean 6 in lift all around for what some pay for a 4-5" lift. Your 4x4 capability will be significantly increased and you could get locking hubs and have the entire front drivetrain stagnate.
