Headlight adjustment
8.9K views 6 replies 5 participants last post by  Markmac
What tool do I need to adjust the headlights up slightly in my 2009 Colorado?
#2 ·
I've seen some with a torx head and others with a Phillips head. The adjuster is in the notch of the grille behind the turn signal lamp
Sent from my SM-N960U using Tapatalk
#3 ·
I have read somewhere, that you should be on level ground.
remove your grill, this may be required, however, I had my grill previously removed. After opening your hood, then behind the turn signals, about 6” below the turn signal light, On each side. I had a thorx adjustment screw.
Place your truck appx. 20’ from a wall and adjust your lights until the center of the headlight beam is about 4’ high. You can mark the height with tape. Reinstall any items removed. It’s that easy. I used a 1/4” ratchet, a 6” extension, and a thorx socket. Can’t recall what size the thorx socket was. Good luck.
#4 ·
#5 ·
Thanks. I was looking for the Torx size or Allen key size. I knew the rest as it is pretty standard.
