So you wanna buy a Low Profile Transmission Cross Member?
68K views 276 replies 85 participants last post by  KM Richards
I'm comparing the different brands/styles and was wondering what you guys like.
From what I can tell these are my choices. Anything else out there that I should be considering?
Jags That Run - $190.00 (Price includes shipping)
Belltech 6963- $211
CleanCut Creations - $140 (These don't seem to be available any more)
Dallas Hot Rod Parts - $119 shipped (out-of-business ...again)
Kryption Fabrications Low-Pro Transmission Crossmember - $110 (add $40 for optional black gloss powdercoating)
Designed with efficiency and innovative features in mind, this crossmember is simply the best bang for your buck. After lowering your truck, the stock crossmember leaves very little clearance between itself and the ground. Installing one of our crossmembers will significantly increase ground clearance and clean up the appearance under the truck.​
This crossmember fits 04+ 2WD Z85 Chevy Colorados / GM Canyons.​
Kryption Fabrications No-Pro Transmission Crossmember - $125 (add $40 for optional black gloss powdercoating)
This transmission crossmember comes from the same roots as our Low-Pro edition. Instead of installing underneath the frame, it sits inside and flush to the bottom of the frame for a truly No-Pro installation. Please note, this is a weld-on crossmember.​
#2 ·
Re: Transmission Cross Member
I run the JTR and i have no complaints just be sure you check the bolts after a few weeks of rolling with it because mine rattled loose and i lost 2 of them, I havent heard anything bad ab out the Belltech crosdsmembers except they are too fucking expensive, and the CCC ones are the cleanest looking but are a bitch to install, do you plan on dopping the truck more?
#5 ·
I have JTR and its priced great, its easy to install. I let the paint dry while I cut the xmember ears off the frame and yeah, it doesn't take long. The Belltech xmember is just expensive because your are paying for the name brand. If you don't want to torch and weld in the CCC, JTR FTW.
#123 ·
I called cleancut creations, as expected they were not there but I will call back on monday and hopefully will have an answer if they will still make them or not. And that snow cone truck on there website is sweet!
that truck came to my school it was fucking sick!
#14 ·
I have the JTR x member and its holding up very well. I have had it on since 05! And its stupid easy to install!
#18 ·
ive had my JTR for 2 years...no complaints. i cut swamp rats frame ears off for his JTR knock-off and we discovered the bolt hole didnt line up. i put grandpointkillers JTR on in about 30 min the other day! JTR FTW!!! stupid easy install
#23 ·
JTR FTW!
4 years on mine no isses!
