21 - 40 of 62 Posts
Hahaha
You won't be able to use the e67, and harness as is from the 07 trailblazer but it's a good start. I can help with the wirring and programming. Go tuners will certainly help! Great start having the tbss. I'd go with obx Colorado v8 hearders. Or stock manifolds.
Interested to see if the TBSS oil pan clears. I've only heard for sure that the V8 coly/canyon and full size truck pans fit.
Yeah because the tbss has the pass through for the half shaft? Might not work? I have a Brocken lh8 pan and baffle, dipstick, could be alluminum welded? In case yours doesn't fit? But I think the new lh8 pan is pretty cheap
The tbss oil pan will def not work. I already have a full size truck pan ready to go but Had some spare time and the tb/envoy pan so I figured id test it out and save and others the headache. No worries tho, truck pans are cheap. Good luck with the build.
I also just tried the driverside trailblazer/envoy exhaust mani and it didnt work. You could possible trim the motor mount down but still dont think it will work. I suggest picking up the v8 coly manifold. The passenger side is the same so youre good there
Discussion starter · #28 ·
Yeah I wasnt planning on keeping the TBSS oil pan, going to pick up the V8 colorado pan kit with pickup tube and baffle. As far as the pcm issue if both my colorado and the TBSS use the e67 pcm then why wouldn't the TBSS engine harness plug right into my e67? Obviously I'd have to reflash the PCM to understand that there's a 6.0L V8 there and not a 3.7L I5 anymore.
That's good info about the exhaust, I knew it was a little too optimistic to think the TBSS manifolds would clear everything alright but 1 out of 2 isnt bad and I can just get a V8 colorado driver's side manifold easy enough.
Project went on hold for a little due to weather and me finding that my rocker panels were already rusting through below the rear doors. Definitely want to get that all cut out and replaced, and make sure the chassis is in good shape before I do the engine swap. In the meantime I've also been cleaning up the LS2 a bunch and going over it. Planning on doing all the gaskets, checking lifters, swapping water and oil pumps, and a couple other maintenance items while it's out and on the stand. Plus I need to give the 4L70e a good inspection too and probably replace the clutches and other seals/wear items.
Well the tbss 07-09 has the pcm, by the left front battery, and all three plugs go into it!! J1, blue, j2 black , j3 grey. There is a massive inline body plug no were near the Colorado pcm that's mounted on the right fire wall!! The Colorado body plug j1 blue is hard wired to the entire dash cab harness! And the fuse boxe plugs are different. So far from plug and play:) sorry to say
The 3.7l pcm can be flashed to a trailblazer ss, but the cruise, starter, and gas pedal from the Colorado won't work then. If you use a 2009 Colorado 5.3l tune then the gas pedal, cruise Ignition switch will all work from the 3.7l Colorado. The pcm is complicated and hp tuners, efi, tuner cat would be lucky to define half the tables available in the pcm file. You can't copy compare your tbss to the Colorado tune file, as your only copying half the tables at best, you'd likely cause the throttle to go into reduced power, from the miss match tables. Even if you use the trailblazer pedal, and a custom ignition switch you'd still need a tune anyway!! Because the minute you change the maf and air filter box, and exhaust, you need a tune regardless. Best way is to start with a 09 Colorado 5.3l, then tune the maf, ve spark tables with a dyno for your 6.0l. Also the tcm will freak out with a 07-08 trans if you use the 2009 Colorado pcm/tcm. I use a special 2008 tcm file for these applications.
Also there are two Slave files in the pcm second processor or flash chip, that need to match portions of code in the engine segments. You cannot use efi, tuner cat, jet dst, or hp tuners to write both Slaves. So you'd need gm software to flash using the vin of a 09 Colorado. I have that software and cable needed to do so. And so do other one poeple. A dealer ship likely won't perform this task for you, but you could ask?
Sorry to hear about your rockers!! Are they available aftermarket or gm? Gm would sell you the hole cab door frame likely?? We don't have that problem in my area there are some sqaure bodies still rolling around with barley any rust? And I've never seen a rusted out Colorado or canyon?
Discussion starter · #32 · (Edited)
The replacement panels are from Sherman and you're right, GM doesnt offer anything in the way of repair panels at all. I was really surprised to see how bad it had gotten but it should be repairable so just another thing to do I guess. This will at least offer me an opportunity to get into the rockers are lay down a thick layer of internal frame coating in there too.
I'm sad to hear how different the harnesses are, I guess there's nothing stopping me from just getting an 09 Colorado V8 harness and using that instead. They're only like $300 and should work with the LS2 since it electrically would be the same as an LH8 (both 4th gen LS-based with no VVT or DOD). Does that sound like the best option then? I have a Tech2 clone so I can flash the 09 V8 stock tune as a base and then copy over the fuel/spark tables from the TBSS tune and adjust cylinder volume to 6.0L in HPT.
As for the trans do I have to do anything with the TCM at all? If I leave the TCM from my 3.7L alone and then physically swap in the 4L70e everything should plug into the harness from what I've seen. The PCM/TCM have some sort of verification handshake that goes on but is that based on anything more than the VIN number?
The Colorado 2009 v8 harness will need the trans portion of the engine harness redone, the 2007-2008 trans is quite different. You will need to strip most of the harness, change wires to the tcm, trans, add a trans range switch, add wires to the fuse box, change modify the body harness to the engine plug. The alt, map, oil pressure and starter plugs are also different from 07-09. I'm sorry there just isn't a plug and play harness available. Not to mention the last time I tried to order a 2009 harness there wasn't any available, sold out.
What tranny's can be used in Colly's
beside Colly tranny's. I need to get one
to rebuild for my trk.
24x gen 3, 4l60e/70e 99-08, 4l80e, ma5 5spd manual, 6peed manual t-56, tr6060
58x gen 4, 4l60e/70e 07-12*, 4l80e, 6l80e/90e, 8l90e**, ma5 5spd manual, 6speed manual t56 or tr6060
*When in hummer h3/355, trucks 04-08, won't have backup lights if using a 09-12 trans. Maybe some 2012 and up 4l60e that fits idk what application still uses it?
**8l90e hopefully comming soon:)
So any Gen 4 07-12 4L60E V8 will work ?
Rock shows the tail housing section
is diff.from any other GM trans.WTF
Yeah but you'll need a specific harness and programming for 07-08. Then a different harness and programming for 09-12. And the reverse light issue. Idk what's up with different tailshafts? 2wd or 4wd
BUICK RAINIER 2004-2007
CADILLAC ESCALADE 2002-2006
CHEVROLET ASTRO 1996-2005
CHEVROLET AVALANCHE 2007-2008
CHEVROLET AVALANCHE 1500 2002-2006
CHEVROLET BLAZER 1996-2005
CHEVROLET C1500 PICKUP 1996-1998
CHEVROLET C1500 SUBURBAN 1998-1999
CHEVROLET C2500 PICKUP 1998
CHEVROLET COLORADO 2004-2012
CHEVROLET EXPRESS 1500 1996-2014
CHEVROLET EXPRESS 2500 1996-2005
CHEVROLET S10 PICKUP 1996-2003
CHEVROLET SILVERADO 1500 1999-2013
CHEVROLET SILVERADO 1500 CLASSIC 2007
CHEVROLET SSR 2003-2006
CHEVROLET SUBURBAN 1500 2000-2008
CHEVROLET TAHOE 1998-2009
CHEVROLET TRAILBLAZER 2002-2009
GMC C1500 PICKUP 1996-1998
GMC C1500 SUBURBAN 1998-1999
GMC C2500 PICKUP 1998
GMC CANYON 2004-2012
GMC ENVOY 2002-2009
GMC JIMMY 1996-2001
GMC SAFARI 1996-2005
GMC SAVANA 1500 1996-2014
GMC SAVANA 2500 1996-2005
GMC SIERRA 1500 1999-2013
GMC SIERRA 1500 CLASSIC 2007
GMC SONOMA 1996-2003
GMC YUKON 1998-2009
GMC YUKON XL 1500 2000-2008
ISUZU ASCENDER 2003-2008
ISUZU I-280 2006
ISUZU I-290 2007-2008
ISUZU I-350 2006
ISUZU I-370 2007-2008
OLDSMOBILE BRAVADA 2002-2004
Please refer to catalog for application details.
Help
Order Status & Returns
Cart
Menu
Part CatalogCHEVROLET2012COLORADO5.3L V8Transmission-AutomaticCase
Parts
ACDELCO 24241496 Info
Press Image to Zoom
4 Speed
GM Original Equipment
{#24208999, 24235668}
CAD$47.58
Add to Cart
Tap to expand
ACDELCO 24247300 Info
4 Speed
{#24211244}
(Only 4 Remaining)
CAD$399.36
Add to Cart
Tap to expand
TRANSMAXX 3526114 Info
Fits4 Speed - RWD; Trans. Code:4L60E
Or4 Speed - 4WD; Trans. Code:4L60E
Remanufactured; Extension Housing (6 Bolt Bottom Mount) 5" Long
Out of Stock
Choose for Me to Minimize Cost
Send these listings to a friend
The Colorado, and h3 pan and valve body are different, to clear the front driveshaft on 4wd, I think. 2wd shouldn't matter
Ok, it looks like a 1996-2014 Chev or GMC 1500
van should fit or a Silverado/GMC 1500 1998-2013
or am i reading this wrong ?
21 - 40 of 62 Posts
