I just had my transmission rebuilt due to losing OD and 3rd, and I am wondering if adding a transmission cooler is worth the trouble? The shop I had it at told me it isnt, but the internet seems to think different. I will be servicing the transmission properly this time around ( I bought the truck used at 150k miles and the previous owner did not keep up with it.) It will be used for lite towing on occasion ( my dirtbike and a razr 1000). I just want to make sure that the transmission has as easy of a life as it can now.
On an unrelated note, GM rebuilt the head at 53K miles. Idle is fairly smooth with an occasional vibration every so often. Is this normal for the 3.5, or should I be worried. I just changed the plugs and the old ones were clean. CEL is on for EVAP purge valve.
