ZQ8 Rear Suspension Rides Rough?
1 reading
15K views 21 replies 12 participants last post by  KM Richards
I have recently recognized something I dislike about the rear suspension on m 09' ZQ8 Canyon. For starters, suspension is all original ZQ8 equipment except for one shock in the rear which the original owner replaced for some reason. So that leaves me with OEM ZQ8 leaf springs, one OEM shock, and one aftermarket (unknown) shock in the rear. No blocks or any other mods to the suspension. The rear leaf springs just seem to be a little stiff my my ride tastes. I am very satisfied with the ZQ8 front suspension, but not the rear. All this brings up a few questions that I have:
1. Has anyone else shared my opinion of the factory ZQ8 rear suspension? If so, what was your solution to the probelm?
2. Are the spring rates different between the ZQ8 and Z85 leaf springs or just less arch?
3. Any other thoughts or opinions on why I may be feeling a rough ride in the rear?
#2 ·
Yours probably rides like a dream compared to most of our lowered ones lol
Yeah the ZQ8 leafs are different from the Z85 leafs and the shocks are also different, also the ZQ8's have a rear sway bar vs the Z85 not having one at all, all that will make it a little stiffer probably
#4 ·
I figured I would get this response at least once! Lol
You could try different shocks. If you can afford it. Go with qa1 shicks
I have considered buying new shocks, but I am just not convinced it is the problem quite yet.
I wonder though if removing a leaf will make the ride smoother? I know people remove them to go lower, I wonder how it affects the ride with the proper shock absorbers......
Only an idiot or a poor man would replace one shock.
This is so true...... Lol
Also, just thought I should clarify my problem in case it was unclear before. For the most part the overall handling and cruising of my ride is quite good, but it is specifically the bumps and pot holes on these damn Oklahoma roads that make the ride harsh. Handles bumps harder than anything I have driven before that was comparable.
So you all think new shocks will fix this?
IMO the stock shocks in the ZQ8 sucked. I have a lot of weight in the bed so I didn't have the harshness. Mine bobbed up and down a lot. I installed QA1 adjustable shocks and I now have a smooth ride. With the shocks being adjustable, I can soften or stiffen the ride.
Also, the light weight of the rear can make the rear suspension seem harsh. Try adding some weight in the bed, like sand bags, too see if it helps with the ride as it sits now.
#10 ·
How much air is in the tires?
Don't expect a new shock to make the potholes treat your truck like it's a Cadillac on a brand new asphalt road. Holes are holes. Those square edges suck.
As for having a single replacement shock, my first thought was the previous owner busted just one, possibly overloaded? Or he hit a pothole with that wheel. LOL But yeah, if the shocks were good then one got busted I could see an owner replacing just one. Or maybe even perhaps it was bad and he swapped it out to sell it to you.
#14 ·
also try lowering rear tire press to 30psi, it really helps.
#16 ·
Alright guys, here is an update. I started off buying new shocks like everyone recommended. After installing monroe shocks from the local parts store it was time for a test drive. Truck rode exactly the same. I decided to get my money back on the shocks since the old ones are obviously still good. So then, I tried the weight in bed trick. This definitely helped! I put a few old wheels and tires I had lying around in the bed and it seemed like I actually gained suspension travel or something. Anyways, the ride was definitely better, but then I started thinking……..no way in hell am I going to ride around all the time with 150-200 lbs. of crap in my bed just to make the ride better! Soooooooooo, I decided to pull a leaf! I figured that removing the second longest leaf was no big because if it did not help then it just slides back into the leaf pack without any permanent mods to the pack. I have to say though………..it rides like a dream! I like the ride so much that I wish this had been my first mod.
#17 ·
Shocks dampen a ride, that's all they do. When they wear out things get soft.
Have you ever owned a truck before? I've never been in a truck that rides as soft as these things. I don't recall ever reading what your tire pressure is either (I asked a while back).
I'm sure now that with your leaf removed you can't even haul that 200lbs of stuff you ha in there before. haha
I don't know what a ZQ8 rides like but I seriously can't imagine that the 'sport suspension' it has is anything noticeably different than the other Colorado/Canyon trucks.
Either way, glad you happy. I'd imagine now the truck floats a lot, maybe even borderline uncontrollably floating. Be careful on high speed roads with little dips and wallows in it, the back in may not settle down very well.
#18 · (Edited)
I live in Oklahoma, I have owned nothing but trucks, lol. I came over to 355.net from performancetrucls.net when I purchased my first small truck. I have built several fullsize trucks and suvs all of which had a smoother ride than my ZQ8. All except one fullsive 4x4 I had with cranked T-bars that rode like a tank! But thats another story.......
I have been running 32-33 psi all the way around. Sorry, I guess I missed this before.
Also, why would you think I can't haul 200 lbs. anymore? I did not remove the overload leaf which is what keeps the leafs from bowing the wrong direction under a load. I am not saying the load rating is not reduce some now, but I can still haul most anything that is reasonable with a 5 ft. bed. I have already tried.
Will have to get back to you on the "floating". My initial opinion is no, but I have really only drove it for about 2 days now, so I will get back to this post with more results as I come across them whether they be good or bad.
#19 ·
i was gonna say the same thing about floating. were from cali and going fast on the freeways here you get alot of floating(i call it bucking) because of the way the shocks are not staggered.
try a freeway, that has a slow turn that drops off a bridge, and let me know what you think.
32-33 psi is a little much imo, but thats me, i run 30 in the back 32 in the front. remember these trucks are light especailly in the ass end. any weight, even a bed cover makes noticable differences.
my truck is z85, but i have swapted out to zq8 springs, after trying stock and belltech....
glad it worked out for you, let us know later how the ride is... good info for sure.
#20 ·
I think 33 is a little high for pressure too, but I don't think so much that the ride would be as harsh as described. I'd expect more like a 60psi answer.
Have you been able to confirm your leafs are stock or has somebody else previously added a leaf?
The only reason I said what I said about the limited weight capacity is because they sag so fast. My truck sinks over an inch when I sit on in, all 155 of my pounds. haha It seems that in theory if you add in a few hundred pounds that it will sink more rapidly. Maybe even worse on the rebound too.
I'm not saying to add the leaf back or that your vehicle is unsafe, just thinking outloud that the removal of a leaf may result in more negatives.
Wolf threw out a great scenarior. Some type of dropoff while in a curve. In reverse of that, a year or so ago I aired up my tires for a long road trip to help with mileage. I hit a bump through a curve and I nearly crossed the paint stripe to my neighbors lane. Completely different suspension though, I'm lifted some. But when the suspension can't react quickly enough, those are situations that seem to amplify bad suspension.
Keep us all informed on how it seems to work out for ya.
#21 ·
The leafs may be stiff but they are really weak. Search around the forum and you will see many that have reported the leafs flattening or even de-arcing. I have over 600 lbs in te bed at all times and run helper bags. My leafs are now "S" shaped.
