2007 CHEVY SUPER TRUCK
Engine specs
*Engine blueprint and balanced by CPR (CUSTOM PERFORMANCE RACE ENGINES)
* LS-3 Hi-rev Road Race 13:1 Compression, E85
* Dry sump, Avaid billet pan, weaver bros.4 stage pump
* CPR Custom Stroker crank
* ARP Main Studs / Head Studs
* TEA Stage 2 heads, 63cc, Blue print valves, LS-3 hollow stem intake, ferrea exhaust, Pac
dual springs, Ti spring retainers.
* Cometic 4.070 x .040
* Carbon fiber LSX Race Valve Covers
* LS-6 timing chain damper
* Hinson C-7 R Timing chain
* GM 2116LSR RACE LS HYD ROLLER
* FAST LSX-RT 102 ported intake manifold, fuel rails.
* Fast 88 lb. hr. injectors LS-2
* Nick Williams 102 Throttle Body (cable)
* ATI Super Damper #917289 /with Dry Sump cog
* 6061 Valley Cover (knock sensor delete)
* Manton 11/32 push rods
* ARP 12 point head studs
* BTR rocker arm trunion, bearing upgrade
* Trick Flow Alum Eng. Steam Kit, black braid hose, alum AN fittings and vents
*Radiator Pod
*Ron Davis Radiator
*Meziere remote elec. water pump
*Spal 2000cfm 16" fan
*Carbon fiber high pressure wind tray
Steering Components
* KRC Aluminum Power Steering pump
* Fk aluminum rod ends
* Sparco CF 385 steering wheel
* Coleman quick release hub
* Ti steering bolts
Vehicle Weight
* 1, Driver Side
* 1, Passenger
* 2,100-2,300 lbs. Total weight (WET) est.
Transmission mods
* B@M 4L60E Stage 3
* B@M Pro rachet shifter with 4' super duty cable
* Custom aluminum Cross member WITH ENERGY SUSPENSION 3.1158G Trans mount
* SONNAX forged chromoly slip yoke, 1350 U-JOINTS
* Derale 18" aluminum finned, return style trans heat sink
* TRU-COOL 40,000 GVW Trans cooler
* PST carbon fiber driveshaft 7075 forged aluminum yokes
Electrical
* Auto Meter Gauges
* Battery Bug
* Quick Shutdown Flag Switch
* Custom TPMS Sensors
Exterior
* Custom Aluminum Hood Brackets
* Carbon Fiber Hood
* Custom Carbon Fiber Mirrors
* Aluminum Adjustable Wing
* ATL FIA fuel cell
* Aeromotive
hantom fuel pump, 100m fuel filter, fuel regulator and fuel press gauge.
Interior
* Gutted the Doors and and windows, and put in Lexan windows
* Status Carbon Kevlar Race Seats
Suspension Rear
* QA1
* M@M pan hard bar
* 3 link with coleman pullbar
Suspension Front
Tires Wheels
* Colorado Custom Billet Wheels 17 x 10 Front and 18 x 12 Rear (Powder Coated Black Magic)
* 275 x 30 x 17 front and 325 x 30 x 18 Rear
Audio
*THUMP, THUMP, THUMP Big Cam sound and way to much going on inside the cockpit. The last thing on my mind would be a radio!
Engine specs
*Radiator Pod
*Ron Davis Radiator
Steering Components
* Ti steering bolts
Vehicle Weight
* 1, Driver Side
* 1, Passenger
Transmission mods
* B@M 4L60E Stage 3
Electrical
* Auto Meter Gauges
* Battery Bug
Exterior
* Carbon Fiber Hood
* ATL FIA fuel cell
* Aeromotive
Interior
Suspension Rear
* QA1
* M@M pan hard bar
Suspension Front
Tires Wheels
Audio
