Cargo Light Override?
1 reading
14K views 13 replies 7 participants last post by  Jremeee
Hi guys,
For the longest time I thought the cargo light was broken... I only discovered just the other day that it works fine, it just has silly settings like the light won't come on unless the key is out, etc.
Is there any way to override this so that it simply goes on and off whenever I hit the switch? I often have the dogs in the bed and the light would be nice for when I'm doing a quick check on them.
Not a big issue, but it would be a dandy little feature for me.
#8 ·
Just locate the wire coming from the cargo lamp, and re-connect it directly to the pushbutton.
Haven't looked recently at the schematic, it may be necessary to reconnect the other side of the pushbutton to a +12 volt source.
The way the circuit world it seems that the cargo light uses the 12v service from the some light to power the cargo light. Imo jump a diode from the hot pin of the dome light to the input of the cargo light this way the cargo light will turn on without back feeding the domes
#10 ·
Or just cut the connection between the two circuits, then jump from a RAP (retained accessory power) source to the cargo lamp switch.
#12 ·
Fine, nothing wrong with that, if that's important to you..
