How To: Calvert Racing Caltrac Traction Bar Installation
103K views 79 replies 29 participants last post by  adrianm2011
Slo86GT
Skill Level
Easy to Moderate (some machine shop assistance required)
Project Time
2 hours or less
Project Cost
$339 + shipping, plus labor cost for bushing installation.
Year: 2004
Make: Chevrolet
Model: Colorado
Style: ZQ8
Engine: 3.5L
Introduction:
The purpose of this write up is to assist those interested in the ultimate streetable drag racing leaf spring stability. Of note is the space requirements of this installation. This kit hangs relatively low below the rear frame of the truck, and can cause issues on a lowered truck, especially where the roads my be bad or the owner may traverse poorly aligned railroad crossings.
The Caltrac system creates a pseudo-4 link using the leaf spring and what Calvert Racing calls the "Force Transfer Links", which are the large turnbuckle-type rods in the kit. I ran into a few small issues because of the Belltech lowering leaf springs I have on my truck, but as you will see, everything worked out very well.
Tools Needed
Tire tool/19mm rachet or a 4 way tire-tool
21mm Ratchet(mid- to deep-well works best)
Large adjustable wrench
2-4 jackstands
Hydraulic floor jack.
Note: You will need transportation to a machine shop for the bushing replacement as the aluminum bushings are over sized and designed to be "crushed" by the leaf eyelets. Be sure to setup a good time before hand so that your truck is down for a minimum amount of time.
Parts Kit Contents:
Here's what comes in the packaging for the Calvert Racing Caltrac Traction Bar Kit:
From this end, you see the loaded Front Pivot Assemblies. This version is called the "Low Profile" as they do not have a second lower adjustment hole, which saves our trucks 1.5" of clearance and is STRONGLY suggested. On this Front Pivot Assembly, there is a very strong spherical bushing equipped tie rod end, and the large aluminum part you see is the Front Eyelet Bushing Kit that must be pressed into the eyelet of the leaf spring.
The rear shot shows in detail the rear mount plate, which are stock rear plates with mounts for the tie rod welded up and powder coated to a very pretty finish. The front and rear brackets are connected by the Force Transfer Links which are threaded for adjustable pre-load of the rear leaf.
Instruction for removal of stock components and installation of Caltrac Traction Bar kit:
1. Park truck on a flat work area, chocking the front tires is advised to avoid rolling.
2. Loosen lugs on rear wheels and jack truck up until the rear tires are 3-6 inches off the ground with leafs unloaded. Support vehicle and axle by jack stands. I recommend 2 jack stands under the rear axle, then two more under the rearward frame rails to support the vehicle itself as the axle will not be supporting the truck while leafs are removed.
3. Remove rear wheels.
4. Remove lower shock bolt.
5. Remove 4 U-bolt nuts under axle mount plate. Set plate aside, save the 4 nuts, washers, and leave U-bolts hanging.
6. Remove front and rear leaf spring mount bolts. This may require lowering the spare tire also. The spare tire can be lowered using the factory jack tool (located under the front passenger seat, in the tool kit). Use the access hole in the rear bumper to unwind the cable wench located there to lower the tire until rearmost leaf spring bolt can be removed entirely. I suggest putting this bolt back in head side out in order to avoid this hassle in the future.
7. Leafs will need to have the front factory rubber bushings and sleeves removed. I had a machine shop perform this step and ran into some complications, as the Belltech lowering leaf I run has an eyelet inner diameter of 1.5" where the factory spring should be 1.7" ID according to Calvert Racing. The machine shop I used called Calvert, confirmed the sizing, called me and advised for a few bucks they could turn this piece down to the size I needed. Make sure you aren't getting ripped off by the machine shop!!! They are notorious for giving "we-don't-really-want-to-do-this-for-you prices" that are extraordinary!!! Even with the custom work I needed, the machine shop only charged me $80, which I feel was a lower than expected price, so I tipped the guys $20 more for the work.
Below you can see the finished product of the leafspring with the aluminum bushing pressed into place.
8. Place the leaf in position to reinstall it, and slide the front bracket over the front eyelet in this manner for installation. Notice that the pivot bar rests on top of the leaf, the tie rod hangs loose below the steel rod that now goes through the aluminum bushing that was pressed in. The setup really is eloquently simple.
9. Reinstall front and rear leaf spring bolts.
10. Install replacement rear mounts onto original U-bolts and bolt back up the shock using all original hardware.
11. Per instructions supplied, screw the Force Transfer Link (big black rod) into the front tie rod end entirely, then with the right tie rod end removed, screw it into the other end entirely to allow for even threading in the front and rear. Once screwed in entirely, hold the rear tie rod end still, twist the Force Transfer Link to lengthen the rod like a turnbuckle, and remount the rear tie rod with supplied hardware.
I suggest tightening these nearly all the way to lift the pivot bar off the spring a good bit before reinstalling the wheels and lowering the truck back down, as once you put the wheels back on the ground, the rods will tighten up quite a bit and you may unintentionally preload the leafs. The specs call for 1/4 turn pre-load after the pivot bar just touches the leaf, and I found that this adjustment can be made by hand with the truck on the ground, but trying to loosen the adjustment at all when pre-loaded was nearly impossible as the tools required are too big to use so close to the ground.
***** AGAIN, YOU CANNOT ACCURATELY PRE-LOAD THE BARS OFF THE GROUND!!!! *****
Once completed, my lowered truck feels slightly stiffer in the rear, but MUCH more firm on shift. I went out and played round some and I must admit, this truck feels VERY solid, and should show much improved traction on and off the track.
Thanks for reading!!!
#3 · (Edited)
Re: How-To: Calvert Racing Caltrac Traction Bar Installation
Not at all :) and I wasn't easy on it. Tried forwards and back, no issues. On my way to work yesterday, I layed into it and did a nice BIG smokey burnout on a not so good piece of road... no bounce, no jitter, nothing. These things are GREAT.
#7 ·
what exactly is the purpose of these...i mean i know they are traction bars but can you elaborate or compare as to what the difference between these and stock are? i might be interested in getting a set of these
the essentially prevent the leafs from wrapping on takeoff, which is what makes our trucks wheelhop. wheelhop causes inconsistent traction situations, bad for racing.
Exactly. They carry the binding/twisting load instead of the spring itself. They'll increase service life of the leaf, and keep the rear end planted, as well as Calvert claims that the new dimensions of the rear suspension under load move the lift center of the vehicle from the front eyelet of the leaf spring to where the angle from the lower caltrac mount, through the caltrac bar hits the chassis, or about center of the door on my truck.
#10 ·
i used to have the lakewood t bars n loved them! traction bars help a lot on these trucks. eliminates the wheel hop! however they do hang low, i bent mine baaad goin over a train track so i had to remove them
#11 ·
how far do they hang down past the hanger and how much more below the shock is it
#13 ·
what model caltracs is that one? im looking for a set but theres so many model numbers which one did you use
That's... a good question. I just called Calvert and said "One set for a Chevy Colorado please." They said "Street or race? We recommend street." They explained the difference... "Street it is. Please and thank you." Done.
#14 ·
hmmm i was looking into a pair online. they didnt have it for the colorado but for the s10...not sure if thats gonna fix it thought. where is calvert racing? number?
#20 ·
#24 ·
so i guess you recomend getting new rear leafs then using the stockies with blockies? thats what kevin said from calvert. i was about to order mine then he said it would be a good idea to swap leafs.....for the new leafs and caltrecs will run me total about 780 to my door...kinda expensive :(
#25 ·
I got Belltech Leafs from another member to lower the truck and keep some ground clearance instead of blocks on stocks. Now that I have a taste, though, I want to put 2" blocks on those Belltechs.
I dunno what leafs Calvert sells... I thought just Mono-leafs, which I wasn't interested in.
#27 ·
I also had the lakewood bars on my truck never had a problem hitting anything .but I got the steet type and after a season at the track and daily driving and MANY 6 grad drop with my 5 spd the worked great I droped my et from low 17eens to my best of 15.7 with no wheel hop at all Iwill be getting a set of lakewood for heavy dut for my next trip the drags coming in oct 1&2 in maryland
#28 ·
do these bottom-out on speed bumps? I have alot of speed bumps around here, and a stock ZQ8 suspension truck!
