If you didn't get it yet, heres what you do (from experiance). Grab the corner of your belt molding on the drivers door, you should be able to get your fingers in there enough to get some leverage and wiggle it up. The belt molding should come right off. Just be carefull that you don't bend it near the mirror, you will have to slide it out from under the mirror. Once you get that off there is a huge gap looking down inside your door. You should be able to just use a scredriver to push the lock rod and unlock your door. If you do wreck the belt molding, its probably a lot cheaper than a new window or a locksmith. Hope you get it unlocked.
