So here lately I've noticed how driving to work.. the same route I've taken for 5 years now, the truck seems to bog down more than usual. I noticed this starting about a month back. I just thought it was because it's getting colder outside. But after reading some of the TC thread I'm starting to think maybe it's my lockup solenoid.
Symptom: Driving at 70 with cruise control on up a slight incline which used to not bog her down, now does noticeably. If I pop out of Cruise and apply a little more pedal the bogged engine noise get's louder, RPM's stay the same and speed ever so slightly increases.
If I let off the pedal then apply the same amount as before except this time in a much faster fashion it will upshift, RPM's jumping close to 3k (depending on incline).
I honestly cannot tell if the TC is locking up or not but from the description from a co-worker in applying more gas the TC should unlock, RPM's jump some, but no downshift which is not what's happening here.
I did search and found a PCM/VCM flash update:
12627883-New software with driveability and fuel economy improvements achieved by decreasing the time TCC will be unlocked due to a misfire rough road event.
Since it mentioned TCC I'm assuming that I should probably do it anyway (awaiting dealer response to price request)
But could there be something else amiss here? There are no codes being generated, the trucks got 77k miles and the last fluid change involving the tranny was at 65K miles. Oh and I've also got the 'corvette' 1-2, 2-3 servos installed.
