Toyota Tundra Dually
19K views 63 replies 29 participants last post by  Lil Black Truck
not sure if this is a repost, i know i have never seen it
#7 ·
sez its a diesel, i didn't look up much im sure you can find info on it though. im not feeling the fenders, they are too big and not tapering back in to the bed at the back looks pretty shitty
#12 ·
With a strong OEM presence at SEMA, automakers are forced to bring The Badass to the masses. Toyota has apparently been overrun with requests from customers for some form of diesel motivation in its Tundra pickup and the automaker has responded... sort of... with the Tundra Dually Diesel. Toyota utilized two Tundra CrewMax pickups that were joined at the hip to lengthen the frame and add an additional foot to the bed. Although the majority of the Tundra Dually Diesel is bespoke show material, the drivetrain has been pulled straight from a Hino medium duty truck, with the only exception being a custom split driveshaft.
The crown jewel of the Dually is a JO8E 8.0-liter inline six turbodiesel, making around 300 HP and 600 lb.-ft. of torque. Shoehorning that kind of mill into the tight confines of the Tundra proved to be a challenge. The body had to be lifted off the frame by three inches and after some hacking and chopping of the firewall, they were finally able to fit the 1,500 pound engine into the bay. Between fitting the oil burner into the snout and mating it to a five-speed Allison tranny, the interior accoutrements have suffered – the HVAC controls are nonfunctional and the massive stick is there to provide additional leverage when shifting gears.
Mike Levine has a great write up covering all the details of the Tundra Dually Diesel, which is worth a read. And even though this mutha' runs, don't expect a production version to make it to dealers any time soon.
#13 ·
Toyota Tundra Diesel Dually Project Truck
"Road Warrior" exterior combined with luxury Interior
10/30/2007
Making a bold and adventurous statement about the contrasts between rugged "Road Warrior" performance and opulent luxury, a Toyota Tundra CrewMax diesel dually project truck made its debut at the 2007 SEMA Show.
At its core, the Tundra light duty pickup's stock engine was replaced with a medium duty diesel powerplant plucked from a 35,000-pound commercial truck. The 8.0-liter inline six-cylinder high-torque engine, made by Toyota affiliate Hino, is mated with an Eaton five-speed manual transmission and a Hino back end. Toyota Motorsports Technical Group heavily modified the Tundra to accommodate the beefed-up driveline.
A host of custom exterior treatments point to the off-the-charts muscle under the hood. Prominent examples include forged aluminum alloy 22.5-inch wheels custom made by Alcoa, a diamond plate-lined bed, a charcoal gray metallic flat paint finish and a fifth-wheel hitch rated at 24,000 pounds.
The muscular theme on the outside shifts dramatically to that of luxury on the inside with hand-sewn ginger leather seats, suede pillars and headliner and dual rear captain's chairs with individual DVD entertainment systems.
PARTNERS:
Engineering by Motorsports Technical Group
Interior by Fast Ed's Interiors
Paint by Focus on Cars
Wheels by Alcoa
Power steps and fuel door by Amp Research
Sound system by Kenwood
Sound installation by Beach Auto Sound
Lighting by PIAA
Exhaust by Magnaflow
5th wheel hitch by Reese
TOYOTA TUNDRA DIESEL DUALLY PROJECT TRUCK SPECIFICATIONS
SEMA CONCEPTS
CAB TYPE CrewMax, 6'5" Bed on lengthened frame
ENGINE Hino JO8E-TB Medium Duty 6 cylinder Turbo Diesel (intended for 35K lb truck)
DRIVETRAIN Eaton 5 speed manual transmission (medium duty application)
Hino Medium Duty rear end with Meritor Axles
Alcoa 22.5X9 Dually rear wheels and Floatation wheel fronts
EXTERIOR (Focus on Cars, Toyota Motorsports Technical Group)
Color Matte Charcoal Metallic
Trim (Theme) Satin Brushed Nickel
Grille Surround Brushed Metal
Bed Raw diamond plate lined
Wheels 22.5" Alcoa 10 hand hole forged alloy wheels
Tires Michelin Energy 295/60/22.5
Suspension Custom dual front struts with Bilstein dampers, Deaver spring pack in rear
Fascia Restyled front bumper insert
Diamond Plate Rear Bumper
Lighting PIAA P4000 Quattro cab lights, LED clearance lights on side and rear
INTERIOR (Fast Ed's Interiors)
Color Ginger soft touch leather with french stitching and perforated inserts
Dash Brished satin aluminum dash panel
Shift Knob Ginger leather wrap
Steering Wheel Ginger leather wrap
Seats Rear bench seat converted to two power captain's chairs and console
Headliner Taupe ultrasuede
Knobs Satin Brushed Nickel HVAC knobs
Door panels Fully leather wrapped in Ginger with french stitching and perforated inserts
Door Handles Satin Brushed Nickel
Door Sills Satin Brushed Nickel
Sound System Kenwood touch panel with full Kenwood sound system
Features Navigation, dual rear seat entertainment
EXTRAS
Reese Signature Series 24K hitch
AMP Research electrically retractable step boards
AMP research billet fuel filler door
Magnaflow 4.5" Polished stainless steel exhaust
#21 ·
It does look pretty sick...
At the same time though, if you actually need to be buying a dually, it probably doesn't matter how it looks since it's probably being used for hauling, towing, and having the piss beat out of it. Jus' sayin'.
#30 ·
ya ford ruined their rep with the 6.0's and every attempt after, i have a 2010 6.6 dmax with 6 speed allison and 52k on it and not a single prob yet. a guy in my same line of work tried out a f550 with the 6.0 and put in a trans at 37k, and by 50k has went through 2 rear ends, plus injector problems and countless other shit, and i see dodge hotshots on the shoulder pretty regularly
new ford diesel is over 400hp and 800ft lbs torque though,,, if its reliable
#32 ·
well i havent had any problems with my 6.0 its at about 60,000 and i push it pretty hard....biggest problem with the 6.0 are the studs, if u replace those ur pretty good to go, couple other small things...but thats with every truck...like dodge and the fuel pump...
And i liked the 6.4 ran one with a spartan 310 tune and the bitch could fly!!
