Z71 on Z85 lift spindles!!!! proven
50K views 196 replies 36 participants last post by  BADLANDER
yes i have achieve what everyone says is not possible, and yes i have a camera but no i dont have a DAMN charger!!! LOL getting an alignment in 4 hours and will be getting a charger at the local target while truck is being aligned. no its not an direct replacement setup. a little fab work was in order but ill document more when i have the time, i have my son today and must wait till the warden gets home to do anything. ill catch you guys later:thumbup:
#27 ·
well with a cutting wheel you must take out the bottom portion of LCA. at first i thought about just bolting the BJ it to the bottom of LCA but i wanted to make sure it was solid so kept the spacers in use. at first i drove it outwith the sway bar (now i know why our trucks need one) than i put it back on and the steering feels about the same even with having the tie rod flipped.
#31 ·
well i believe the reason its 5" is cuz of the cross member that kit supplies, spindle itself may only be 3". with this springtech spindle lift however i netted a good 4". can anyone believe that?
to everyone remember there are pros and cons with this setup. the only con ive experienced is that ive lost about quarter turn each way
