Rough Country Lift?
5.3K views 29 replies 12 participants last post by  OJwerks
Hi all, I was wondering if anyone has used one of these or knows anything about them, I'm looking for an affordable way to give the truck a little better stance and clearance.
http://http://www.roughcountry.com/chevy-colorado-lift-kit_920.php
Also my father has a 2011 silverado 1500, we are probably going to upgrade his rims and tires, I was wondering would I be able to use those Rims on the colorado?
#2 ·
I think optrix used a kit like that on his but most people just crank the stock bars or get lift keys and shackles
And the 1500 wheels will only fit if you bore the hub hole on them or run spacers that are thicker then the lip on our hubs ( the Colorado hub flange is wider than the full size flange )
#4 ·
Oh and his tpms sensors will not work with the tpms on our trucks
Not sure what year your truck is buy 07+ have tpms and ours is on a diffrent frequency than the full size
#8 ·
And I don't know about the lift , I don't know how there t-bar spacer works but I think the member on here optrix used the same thing on his truck might ask him for some in site on the kit
#12 ·
Stay away from anything Rough Country. Shoddy craftsmanship/fit/finish. I just converted over from the maniacs of the Jeep world. We all scoffed & turned our shoulders to Rough Country users. At LEAST go with Pro Comp. Or Rubicon Express, etc.
I went from this(4" Pro Comp, JKS Discos, RR HD Steering):
To this:
#16 ·
Search for torsion bar crank , or look at suspension maxx there a vendor here and they sell lift keys and shackles and diff drop spacer which IMO are needed when cranking the bars with keys if you call and ask for Larry I be leave he gives a discount to forum members
#20 ·
The "kit" is a metal spacer for the front. Unless that spacer is made from crap metal then it will fail. I'll go on a limb and call it a 'glorified washer'.
If you go with the rough country just look at the shackles and see if they look to be poorly constructed. If you aren't happy with the quality send it back. A lift kit has many components that are more susceptible to flaws without a doubt. I've of some brands that bend brackets when a truck runs up over a curb to quickly. Lots of leverage, etc on those front end parts. For the rear, there isn't really any lateral options on the shackles.
I have SMAXX produces installed on mine. But for the sake of argument, you can get your truck to set level without buying anything, however the rear won't lift.
#23 ·
#28 ·
Sounds like the kit is designed to get slightly taller than stock. You can tell the size of the spacer can't lift the front too much more than that of what the stock keys alone will allow. A 3/4" rear sounds about right in comparison.
04CanyonCrew, I don't know that you can truthfully say it's crap. With any key/replacement all you do is crank the crap out of the bars. There is no way around that practice at all. In this case, it just doesn't lift it as much as others. And the 3/4 out back and the amount from the front will probably still result in a level truck.
A person has to understand that even with SMAXX keys, you are still cranking up the bars. They just allow you to go further than the stock limitations, just like the Rough Country spacers (RC doesn't allow you to go as much though). Same thing with ReadyLift keys.
#30 ·
buying keys is a waste of money unless your T-bars are sagged or you have a cow sitting at the front of your truck and need to compensate for weight ... which is the same thing as sagged t-bars.
You should be able yo just crank your stock keys to net you 2" of lift, and get some rear shackles, I just bought a set from ebay for $50 shipped and the quality is killer.
take a look at this video... you dont need any "kits" to crank your T-bars, save that money for the alignment you'll need afterwards.
