With my Sierra the 2500 hd bars would fit no issues in that regards the problems came about simply because of the degree difference between my stock bars & 2500 hd replacements. The front end measurement with the hd bars was sitting at 40" ground to the fender lip it was perfect for the height I wanted but the upper control arms bottomed out against the frame therefore acting like there was no suspension just the tires to absorb the bumps and could not get it aligned properly or at least reasonable.
I'd suspect that the torsion bars are all the same length for the 355's as they are for the Fullsize GM line, the issue may be just the degree change with the bar which may or may not lead to the same situations I had with my Sierra although since there is really only two different bar set numbers if memory serves me correctly this may not really become an issue. There is not a huge vehicle weight difference between the various model lines / engine option.
Curb weight w/ Z85 suspension (kg / lb)
Reg EX CAB CREW CAB
I-4 with manual: 1,527 / 3,366 1,614 / 3,559 1,691 / 3,728
I-4 with automatic: 1,542 / 3,399 1,629 / 3,592 1,688 / 3,721
I-5 with automatic: 1,567 / 3,455 1,655 / 3,649 1,715 / 3,782
V8 with automatic: n/a 1,764 / 3,889 1,820 / 4,013
